How to fix loose mirros
monstar
Found an easy fix for loose mirrors on my S4RS tricolore and thought I'd share. On the underside of the mirror carefully drill a 16mm hole with a flat wood drill bit, then you can put a 10mm ring spanner in through the hole to tighten the nut up against the spring. Because the holes on the underside of the mirror the repair wont be seen, just use tape or grommit to cover the hole.
