How should one check one's oil level?
Popeye
Engine running or stopped for a level between the two lines?
I topped up to full (top level) and then started the bike (748). The level eventually settled out the bottom of the glass somewhere.
Now all your average marine engines have the sumpes checked with the engine running, but everything I see on the interweb about 748's says that the level is set with the engine stopped.
Be quick. I'm off to Donington Saturday morning ;)
TIA
stopped, warmed up ( a 10 minute blast not just a few seconds on stand) bike upright for me.
Gents with the motor running the oil is being pumped around the engine at quite a rate of knots. The window isn't gonna ever give you an accurate reading! Its not a good idea to fill the thing to the brim otherwise worst case scenario it can start bursting seals and p1ssing oil out everywhere.
As Paul says make sure its up to running temp to get the best reading. :)
...oh and upright and on level ground of cause :)
As above but I let it sit for a minute or two before checking to let the oil settle. It usually rises by half an inch or so and as long as it is between the two lines I'm happy.
Warm and level as above.
Checking the levels with the engine running has been on dry sumped engines in my experience. Possibly marine engine is dry sumped.
...yes I had to check all blo0dy (expensive) 15litres of the stuff while the motor was running on certain German sports cars I owned. And the dipstick into the oil tank was over a metre long!!!! :rolleyes: :p
.... And the dipstick into the oil tank was over a metre long!!!! :rolleyes: :p
Let me guess......which you had to check one handed because the other hand was holding the engine lid because the struts were as much use as a chocolate fireguard?;) :D
Or did you have the piece of wood cut to the correct length to use instead?;)
Ah-ha, a man with experience of the beggers!!!! No Stewart, I kept them only until they died, then replaced them imediately, only about £10 a shot. lost points in Concours if the engine lid didn't stay up!!!
...god I was sad then (before Scott says it, even more than now!!) :p
