How difficult to replace rockers on 748SP?
Replacing the openers is very easy. You'd need to take off the belts, remove the valve covers and the rocker spindle covers. Then use a slide hammer or a draw bolt to pull the rocker spindle and the rocker will just slip out.
The closers are a bit trickier. Do all the above plus remove the bearing support opposite the cam pulley, remove the screws for the pulley side bearing support and withdraw it along with the cam. This will give you access to the closing rockers. Pull the closing rocker spindle and it will come out along with the spring.
The difficult part is re-fitting the rocker spring. It can be difficult to lever the tang of the spring back on to the lug in the head.
And of course every rocker that's been changed will need re-shimmed to the correct clearance, although they may need doing anyway even if the rocker is ok.
Are you sure that all of the rockers need replacing? It is much commoner for the chrome to flake off the openers than it is the closers and the only way you'd know the closers are worn is to remove the cams for a look. I'd advise you to pull the cams and inspect all of the rockers before deciding on a course of action.
Workshop wizard suggests leaving them and keeping an eye out at the next service, especially as it'll just be used on dry, sunny Sundays (when was the last one?) rather than blow another £400 plus on it - will probably do that.
