Hid
Easyrider290
Just replaced the Candle in my 900ss to a HID unit.
F**K me, I can see. I feel as though I have been touched by Jesus.
£70 for a kit.
The main beam/dip is a solenoid that retracts something or other, thus it works ace.
A doddle to fit (coz I am mechanically/electronically unsound).
hid
according to this months ride magazine hid lamps on motorcycles are illegal.only legal on cars if fitted with self levelling suspension:confused:
Can they be fitted to an 848 as my lights are not too good. Found this out today whilst riding home in gale force winds and driving rain.:mad:
Think Ride got it wrong, it could be only fitted when auto level adjusting lights are fitted.
There's a lot of cars out there with HID as an option but definitly do not have load compensation.
Got them on the 749 and think they,re ok but every time i pass a road sign that is white it flashes blue .
Takes a bit of getting used too as i always thought the police were behind me..............Scared the pants off me to start with...:eek::eek:
Who cares?
Cars must have self-levelling headlamps and headlight washers. There are no regulations for bikes so you can fit what you like. BMW offer HID on recent models - no self-leveling, which would be near impossible on a bike anyway.
Can you fit it
You get a kit to match the bulb type. Mine was a H4 bulb replacement kit, not sure what yours is.
You have to connect the connectors to the original bulb to a control unit. This is connected to a ballast that looks like a really small recifyer and then to the new bulb assembley.
You also need a feed from the battery and a earth point to the frame.
Dead easy really.
The only issue I had is that the new bulb assembly is longer than the original so it took some wedging in and moving wires to speedo etc...
A few people on Ducatisti have done this. The bulbs on the 848/1098 are H11 and you would need 2 x H11 kits, one for dip and one for main beam, or you could just fit an HID kit on the dip which is the one you really need.
The HID takes around 10 secs to acheive full brightness after switch on so you might not want one on main beam anyway. I have and it doesn't bother me since dip is on at all times anyway and if main is off for less than 15 seconds or so it comes back on at full brightness.
Easyrider's HID is an H4 replacing a dual filament bulb and has one arc that is on all the time with an internal solenoid moving the arc between dip and main positions.
Since there is around 10A of current drawn at switch on, reducing to around 3A as the lamp warms up, you should really have a relay in the dip circuit activated by the light switch, to switch on the dip beam HID. There is already a relay in the high beam circuit.
