Help please on 748 Tyre choice
rmarinel
Well after the weekends playing on the Highland Fling, my front tyre has had it! Strange the front has gone before the rear, must be my style of riding coupled with the sand paper like road surfaces!
My question relates to tyre profile on the front, should I be using a 120/60 or 120/70? Some manufacturers are recommending the 60 others the 70 (and others say either)! I have a preference for faster turn in as it can be a bit slow to turn at the moment. Also I am thinking of swapping to Michellin PR2.
I currently run BT016 which I am reasonably happy with but fancy a change!
Thanks
R
As tyre choice is often subjective and can be a lot to do with rider personal preferences, my only comment would be to be wary of the 70 profile tyre as this can rub on your front mudguard (certainly did when I had one on my 748R).
Thanks Guido - another question on rear wheel removal - how easy/difficult is it? If not too dificult, anyone local got a socket that I can borrow?
Thanks
R
70 profile tyre is standard on the 916 which has identical chassis so can not see why this should be a problem. I changed to a 70 profile on my 748 years ago and much prefer it to the 60 but as Guido says it is down to rider preference and with me it could be because my other bikes all use a 70 profile.
Sadly I have a bi-hex rear nut on mine so the socket wouldn't help.
They're pretty straight forward to get the rear wheels off..........once you get the nut undone that is. Due to being single sided, the torque needed is pretty high so equal effort is needed to get the (often seized) nut off.
Best done using a breaker bar. I have a 1metre long one and that brings it off no problem. I lock the back brake using a piece of timber sat on top of the rear brake pedal and wedged under the frame lug. You can bend your paddock stand trying to get the nut off so it's best done with the bike sat on the sidestand (or even better with a mate sat astride it so there's no risk of you tipping it off the stand as you concentrate on the nut).
Check the rear wheel nut (RHS) torque when putting the nut back on. Think it's 157Nm from memory but best check so you get it right.
Have fun......:)
Guy
You're more than welcome to nip down to East Linton if you want to borrow sockets for the rear wheel removal-have paddock stand if required as well-Graham.
Thanks guys, I've plumped for a 60 profile and I'll see how it goes! I think I'll get the local garage to do the 748 as he said he'd fit the pair for £40 as it's so easy on the 748 - it would be £30 loose so well worth the tenner!
I bought a second set for the SC and then got home to see the CB needs tyres soon as well:eek:! 3 feck'n sets of tyres in one go.............:mad:
