Gizmo
Your a star mate, the half hour job took nearly 4, but it was successful.
The bolt at the bottom of the shock was a pig to get off, once we got the old tie rod out one of the the ball joints came out a treat, then took me an hour to realise the other end has an oposite thread, (Should have looked more closely at Gizmo's reply)
so if anyone else tries this please remember this point as it will save a load of time. (Ooops)
Also I was warned about loosing the bottom bolt into the swing arm, again this was top advice, as this mistake can be made without realising, once the bolt is loose use a magnetic rod to remove the bolt. If not the bolt could easily fall into the swing arm.
This is a 2 man job so would recommend not trying this on your own. Also remove the rear footpeg brackets from both sides and the rear shock pre-load knob for ease of access.
A jack is needed under the engine to lift and drop the bike to take the weight off the rear end.
But Karen is happy with the mod so I hope she will feel more confidant as the following days go by.
But thanks again for all the info offered :beer: :lol2:
