BruceCampbell
As I am getting old and suffer with that white finger thing.....seriously thinking about heated grips, whats the best option out there, dont want them to look ugly on the monster....thoughts please Ta
Diavel likes the cold air though - it seemed pretty spritely this morning.
Theoretically you could. Pin 1 has a red wire straight from the 30A main fuse and pin 2 a black wire to earth. The other 2 wires go the ECU and the clocks. You wouldn't want to make any mistakes with theseTa for the responses....... May go heated gloves but my worry is accessing the battery on the monster to get a live feed to the gloves...I dont fancy taking the tank off with all its plumbing to do that, would they work off the diagnostic feed?? just a thought...![]()
On the subject of wiring, I bought a set for my sc which I hope to install in the next week or so, (i recon i'm really going to feel the cold when i'm back.......said from the side of a pool in Florida) and was wondering where the best place to wire them into was that is close to the bars.
Any thoughts?
R
what wattage are they rated at?OK, so I installed them this evening, I couldn't find a free fuse so installed an inline fuse so connected to the rear light circuit. Anyone see a problem with this? I only had a 15A fuse so used that, but the instructions have no info on what size of fuse to use!<br />
<br />
Any thoughts on which size fuse to use?<br />
<br />
Thanks<br />
<br />
R
Isn't that one of the joys of fuel injection...
cold air = denser air
more air = more fuel = more power
I used to run a turbo car and cold evenings were grrrrrrrrrrreeaaaat!
If they put out 60W, which I very much doubt, they would be drawing 5A so I would fit a 7.5A inline fuse, although in all honesty they are probably more like 30w so a 5A fuse should be fine.There's no info on them (well none in English!)- they are the type that go under the original grips - made in China with all the packaging in Chinese! They only cost fiver off of ebay and I see on the motocross forums that they are fairly popular, although can'r find fuse info there either!
