headstock bearings
wulfie
hey all im maybe looking into changing my headstock bearings on the bike.
But ive heard that the OE one that are on it just now you can't buy them new? and just to replace them with after market taperd bearings?
??? i dunno :confused:
I don't know if the OEM bearings are available or not, but I'd fit taper rollers anyway.
As usual, no idea, but I'll have a go;
If it is OE you want - have you actually checked with a dealer? I have been pleasantly surprised (cheers Harry ;) :D) at the availability of sundry items for a bike that was discontinued 14 years ago.
Next stop the service centres / enthusiasts. ERS / Cornerspeed / Ducati John etc etc They will know the dodges and (bearing manufacturer) part numbers even if they don't have the stock.
But most towns have a bearing supplier. If someone can give you the references (I don't have them, JHP did my 748 ones as part of some other work) or worst case you have the old ones in your pocket, pop along on a Saturday morning to the trade counter for a 'cash sale' ;) It is just a case of IDxODxDepth then stuff like tolerance and whether they are open or sealed, type of seal. Get SKF or some other name you recognise. Prices will be quoted less VAT, but you should get 40+% off list price before the VAT goes on.
Avoid eBay, Busters, M&P (i.e. 'bike' suppliers) - they are fine for purple iridium screens but buy bearings from a bearing supplier.
Good luck
Hi Wulfie,
Just got a set of head bearings HERE last week.
"All Balls" was recommended by our technical guru and Wemoto themselves.
I phoned them and had the order the next day. Painless and good quality stuff.
Hi Wulfie,
thanks all i was looking at the ones on wemoto but i wasent sure weather to get the all balls one or the OE ones. ya know just to be sure :D
I Uprated to taper rollers simply by taking the old bearings to a trade stockist - 2 x SKF Tapers for £22 but, it was a few years ago.
Unable to confirm full but codes I've found for bearings (and equivalents):
Timken: (Taper Roller)
L44613 Outer race
L44645 Bearing
FAG:
509592A Outer race
509590A Bearing
SKF:
639172 Outer Race
639174 Bearing
Actual OEM bearing size is given in mm as: 26 x 52 x 15.5
(Internal x external x height)
