Head race removal
ShedBob
Any particular suggestions about removing the bottom race from the bottom yoke of a 748sps ?
ShedBob
<embed src="http://blip.tv/play/%2B33CrEEC" type="application/x-shockwave-flash" width="480" height="390" allowscriptaccess="always" allowfullscreen="true"></embed>
The video shows them removing a taper roller bearing which was easy once they'd cut away the cage and removed the rollers because there is a lip to get the drift up against. You won't manage that with the cup and cone bearings because there is no lip.
You'd need to use the Dremel (or anglegrinder if you are very careful) and cold chisel method mentioned by Gizmo, or if you are very lucky drive a thin wedge between the bearing and the yoke to push the bearing up.
Nowt wrong with a good angular grind if you get in the correct position and hold it firmly.
Dremels are for girls!
true girls have better attention to detail and take more care exactly what is needed when you dont want to damage something :), I was in a taiwan frame factory a few weeks ago watching some very thin aluminium being welded, on the most intricate welding line every welders mask had a pony tail out of back of it, 4 girls doing stuff a bloke couldn't, I'd never seen welding like it, manager was saying they didn't have one male welder that could weld like that on less than 1mm thick material.
