Handlebar grip removal
GDBD59
Member
I'm changing clip-ons & for now would like to remove the left grip. Viable or not.......technique advice please.?
I bet some 4* would loosen it.....Ive seen the golf pro's fit golf club grips using it.
I would fire some good old Wd40 down there and leaving it to soak for 10 mins.
I am probably wrong though.........stanley knife should work a treat in the end ;)
Knife it if you don't want to re-use it. A long thin screwdriver (or a bike spoke) pushed underneath and then some hair spray to lube it. Rotate the spoke (or whatever) around the grip and it will move off. Be careful not to split the rubber. Re-apply with more hairspray and leave to set overnight. Peasy.
Didn't realised you were multi-talented:rolleyes:
Can you fit me in for a cut and blow-dry;) :D :D
Any particular brand Sir would recommend? :lol2:
the easiest way without resorting to chemicals and blades is to use an airline, carefully insert under the grip and add air :) wiggle it as you are doing it and it'll slide off. we fit all our rubber mountain bike grips like this, the sleeved ones are a bit different.
Alas, I don't have the technology. :(
Amazing but true! Worked a treat. :)
Thanks. Gary
