Graunching Clutch Noise
454697819
On the ST2 2002 model if I accelerate under medium power and "Slip" the clutch a little there is an Awful graunching noise.
It only happens when its hot and it can be ridden around but it doesnt sound "right"
There is dust being flicked about as I can see this in the clutch window, but it fuctions normally so to speak.
Any ideas?
Alex
sounds pretty normal for a dry clutch. Could check the bearing in the clutch pressure plate and take the push rod right out and give it a could greasing...
Any ideas?
Alex
This is usual for a dry clutch Alex. Take off the cover, and blow out the dust to sort it.
yeh , i get it especially on a hot day in traffic, seems to be normal on st2's and a couple of others.not to worry:D
thats great,
As long as its not about to launch itself thats fine,
Does the gasket screw itself up if I take the casing off?
Just want to sort these niggles before I entrust our holiday to the bike...
Gasket will be fine, not strictly necessary anyway. Some put spacers between clutch cover and case so the dust escapes.
Any ideas?
Alex
another suggestion I'd do other than the useful ones you got above, is to take the clutch pack out, clean it all up and swap the plates about a bit, your plates may have become slightly glazed due to heat, so giving them a light rub with 150 paper will roughen the surface up a bit. Ian is right about giving the clutch some air (if you are not already running an open or vented clutch cover). :)
