Gearbox Issues
richc
Evening all!
My 900SS decided to eat its crankshaft oil gallery plug last year. During the stripdown we've discovered that one of gearbox gears is badly pitted. The 6th driver gear on the input shaft, 28 tooth one.
I'll be putting a wanted thread in the for sale/wanted section. Does anyone know of any alternatives that could go in there? I've been told that 916 gearbox's should fit in. I also know of a 900 with a S4R gearbox in it.
Any thoughts would be appreciated.
Thanks
Rich
The gearbox from any 6-speed engine with single phase alternator casings will fit. The internal ratios for the 916 are different from the 748 and they are both different from the SS. I don't know what they are on the 851& 888. The ratios are the same for the 906 Paso, 907ie, 900SS, 900SL, ST2, Monster 900 and also the Cagiva Elefant and Gran Canyon.
There was a close ratio gearbox for the 900SS but I'd think that it's rarer than hen's teeth.
Thanks for the info Derek.
Just to be clear, any gearbox from a 6 speed engine with single phase alt casings will fit, the ratios will just be different than my current 900? So the gearbox from a 916SPS, close ratio gearbox will fit. Do I want to start mucking around with the ratios, or am I better off sticking with what I've got? My 900 is a 944cc with lightened flywheel, Stage two Dynojet, etc.
Cheers again! :beer:
