Gearbox Cover - 996S
Webbo
Went to move the bike today and noted a wee puddle of oil under the fairing. Thought I have a closer look found some engine oil in the fairing - very strange as never had anything in there before.
Then slowly the blood drained from my head :eek: as I noted the gearbox casing has cracked all around the inspection hatch - Aw f**k. (See attached pic)
As a newbie to Ducati - is this common, any ideas how / why this happens. And most importantly does anyone know where I can get a new bit / or get this fixed near Aberdeen!! (Although I can most likely do it myself if I can get the parts as I have done several engines in the past)
Any advice would be much appreciated
There was someone with a bike on Ducatisti with this problem a few months ago, although it's certainly not a common problem. I don't like to be the bringer of bad news but the most likely cause is crankshaft run out due to main bearing failure. There is a small bearing in the case but it won't be the cause even if it did fail. There is the possibilty that the flywheel has come loose which is common on the earlier models but that usually causes damage to the shaft not the cases. I'll see if I can find the thread on Ducatisti and post a link to it.
Cheers for the advice so far. The bike had a major service just before I bought it last September so assume this would have been taken off in the process? I've only done about 300 miles since and as I read the string on the STI forum it doesn't look good!!
Especially as I have just booked up to go on a European tour starting 1st May!!
Guess I'll get the casing off this week and see what I find - I'll post pics as I go. Wish me luck!:eek:
Had exactly the same problem with my 996S years back. It was the main bearing and a big job (under warranty)
Had a similar thing on my 996, the alternator nut comes loose (is retorqued every 12,000 miles from memory) and thing eventually ripped through the alternator wiring and caused the bike to misfire intermittently.
I needed new casing, alternator and a few other bits and bobs, cost around £1000 in parts, Ducati didn't want to offer warranty initially until I produced some interesting facts from the other side of the pond.
Good luck!
Out of interest as I mentioned the bike had a major service approx 300 miles ago. Do you think I have any kind of comeback for this failing so soon afterwards (assuming it is the bearing - the bike has only just done 6500 miles and was running really really well - no excess vibration at all.
Also dropped the oil last night and next to nothing material wise on the sump plug and the pump filter clean as a whistle. I'm really really hoping that it has happened when removing the casing for the service check and the guy put too much pressure on the casing when using the puller - Also interested to see how easily the casing will come off as I obviously can't use a puller!!
Any advice of what I am looking for when I open her up? I have the Haynes manual for reference but as I say not been into a Ducati engine before - always cars and jetskis.
Cheers for now
Part of the major service is to check the flywheel nut is torqued up. If the flywheel nut has come off and caused the damage then you should have some comeback. Either the nut wasn't checked at all and it has now come loose or it wasn't torqued sufficiently when it was checked.
On the other hand main bearings don't usually fail suddenly but very occasionally they do. it would be much harder to prove negligence on their part if it is bearing failure.
Once all the screws are out (remember the one hidden below the clutch slave) the casing shouldn't be too hard to remove. Gently tap it all round the outer edge with a rubber mallet or something similar. This should break the sealant and allow the casing to come away.
Obvious thing to look for - is the alternator nut loose?
Main bearing play might be harder to spot. Check for any up and down or back and forward movement of the crankshaft. Any movement will be very small. If the fault is with the clutch side bearing the movement will be on that side allowing the shaft to rock on the alternator side bearing so it may be necessary to pull the clutch cover off as well so that you can check. A Haynes manual might be handy at this point. You will need a clutch locking tool to hold the clutch so that you can undo the nut to get the clutch off. You can then remove the clutch side cover. The crank is shimmed to take up end float so there should be no side to side movement either.
I hope it something simpler than a main bearing problem. Good luck.
Not a technical suggestion but more of a practical one with a view to possible negligence claim.
Assuming you are taking the casing off yourself it may be worth either videoing the procedure and/or have an impartial witness on hand should the nut fall out when you remove the casing.
It might also be, even from a point of courtesy, worth while to at least notify the garage who did the service of your predicament and intentions and give them a chance to investigate/remedy although you may want to have someone present if they remove the casing etc. to protect your interests.
Totally agree with you there Stewart,You need to cover you're back with cases like this, good luck Webbo :thumbs:
Cheers for the advice all.
Was planning on calling the garage that did the service this morning - as you all say best to give them a heads-up.
Will also get a mate to video me removing the cover.
Derek - thanks in particular for the advice so far. Really glad you've picked up this thread!!
Couple of pics of the drain plug and the filter basket for now.
Well the cover is off and the nut is in place and tight as a tight thing - absolutely no indication of any damage what so ever. Also no trace of any metal on the rotor either (which I would have thought would be the biggest magnet in the engine) No trace of anything in the residual oil in the area either.
Looks like I'll be going for the clutch side next as suggested.
Some more pics..
Aww bu**er
Thanks again for all the advice. Took the clutch side cover off and all was looking OK.:)
Came back to the alternator side and tried side to side movement and still nothing:)
Then gave the alternator a wiggle up and down - you guessed it, it wiggled:eek: Looks like a bearing issue after all.
At this point I don't feel I can go any further - I don't have the expertise / time to strip it all the way down and diagnose from here.
Can anyone suggest who I can use to effect the repair from this point. I can get a van / trailer and can deliver pretty much anywhere (I live in Aberdeen). I tried to load a video but it's 13MB so have put on you tube.
http://www.youtube.com/watch?v=uKz-SHwSV0k
Any recommendations / numbers would be very much appreciated. Please send me a private mail if you don't want to publicly list any numbers etc.
Cheers - A very sad Webbo:sick:
Is there movement of the crankshaft when you press the flywheel
as there is a shim washer that fits behind the roller bearing that the starter gear sits on which is behind the flywheel the can split and half stay in place
etc,or come out completely.
you have it stripped down this far i would take the flywheel off and have a look at that.
that is if you have no lift on the crank.
brian.
Hi
It was my 996S that had the same issue.
Was fixed by Ducati John (cellier) for about £1100
Got the shells replaced etc at the same time though.
Whats the current state of play?
She's back!!!
Well,
After some tense moments on my part the Duke is back in my garage. It was indeed a main bearing failure (Alternator side) that caused the grief. A full strip, replacement of 3 bearings (Both main and the smaller alternator cover one) a fair rake of gaskets etc and she is running as sweet as she was before all this happened!!
Ended up at ERS racing in Dunfermline and I have to say the service was top class. Rebuilt to a tight timescale (I'm off round Europe next week) and even cleaned and polished for me to pick up.
Thanks for all the advice and help given on this - I hope from now only to post good stories!! I'll put up a thread with pictures etc when I get back from Europe - hopefully some nice weather and roads ahead to make that bill worth the pain!!
