Gear change bush - 774993421
Pict
In theory this should be easy to change - push the old one out with the new one using time honoured threaded rod and socket method, maybe making up a wee mandrel to keep everything centred as it is a pretty thin walled bush.
Need someone who has done it to advise if it's that straighforward or a bu99er of a job :rolleyes:
Also, is the ID to size or does it need reamed post installation?
I made up a wee mandrel that popped the old one out and the new one in no bother at all. Gies a shout if you want a wee shottie..
