I’ve been trying to purchase a reasonably priced gas analyser for setting CO levels on monster and 1098. It would appear the analyser of choice is the gunson measuring levels from 0 to 10%. There are mixed reviews and I’ve been trying to purchase a second hand snap on but outbid several times as there’s a lot of interest in such devices. After approaching a past colleague who’s setting up his own company next year designing and manufacturing micro scale precision multi gas analysers I asked him to consider a feasibility study regarding the design of an accurate, easy to use, small and quick warm up time analyser. Expensive units ideal for motorcycles use the absorption coefficient of CO which sits at 4.6 micron. We’ve both concluded that a design incorporating an infra red light source, miniature pump, band pass filter ( 2 bands ) one for reference and one at 4.6micron, integrating sphere, IR detector, electronics ie amp and heater drive, micro controller and display. The advent of small and very fast PC devices like the raspberry pie allow fast processing times to implement the Fourier transform of the incoming data in real time to peak detect the 4.6micron CO peak. If successful we hope to market the product with a main remit of accuracy, quality etc but within a reasonable price.
Carrying out this process for motorcycles without proper ventilation does present real dangers. The CO can only be adjusted if the cat is removed and the bike runs open loop i.e no feeback from lambda sensor. Here’s the real danger the cat is there to add another oxygen to CO turning it into CO2 which is less harmful and better for plants. We’ve removed the cat so presented with CO and hydrocarbons. Health wise three breaths of CO at 1.28% ie 12800ppm will kill you instantly. On bikes we aim for around 4% i.e 40,000ppm ?? Extremely dangerous so something you shouldn’t consider if unsure.
Anyway I’ve agreed to design and manufacture the electronics and assist in the algorithm so sometime soon it may be on the market.
