Fuel tank overflow / drain thing
Biscuit
andpotato
In front of the fuel filler aperture there is a hole which fills up with rain water / soapy water / excess fuel, should it not drain away? After washing the bike i tend to soak up the fluid with kichen towel but annoyingly after filling up i always end with petrol spilling over when i brake hard and going all over the front of the tank, block pipe somewhere or is it a feature?
Steve, I would imagine that like the other Ducatis on the 749 the drain hole is connected by a rubber tube inside the tank to connector on the underside. This is connected to another rubber tube and usually exits at the back of the gearbox on the opposite side from the chain. Check the tube for being kinked or blocked.
I dunno if Charlie Dimnock visits here or not? ;)
SSSSHHHHHhhhhhhhhhh!
there is a tube that sticks out the bottome of the fairing, it is connected to that.
/ian
if you want to pop round one day we can use my airline to blow through it. it might clear it out with no bother.
Thanks guys, ill be taking the tank thru the week and have a looksee, Cheers
Its the two pipes that come out the front of the tank then connect to Y conn then drop down by the head stock down passed the battery box, not sure if they blocked or the nozzles in the tank? will have a peep one eve this week. Not a big prob compared to recent events but annoying nevertheless :comp2:
Theyre just fuel breathers i think......
according to the manual they the breather and drain pipes. Nowt else on under tank that 5 recall?
VERY, VERY, VERY important to keep that drain unblocked, the water goes into the tank, rusts the tank clogs up the fuel pump nearly a 2,000 fix, very common fault, when the bike is laid up over winter remove tank drain it out and get it coated inside.
F*** ME you own an AIRLINE !!!!!!!!!!
Im no engine techy but does that not mean 1 goes to the outside air and 1 back into the fuel system/tank??? :confused:
Im sure Derek will be along tomorrow a.m to set things clear.....;)
It is the one when you open tha actual fuel filler there is a little hole there, same as MTS t goes to a rubber hose straight out to the floor.
you never boarded a rockjock? my my
I will ask someone more knowledgable than me, if I end up buying a749/999 the first thing that I will do is look in the tank, a lot are full of rust, especially 04's for some reason. A teflon spray or paint should do the job but it is the doing, 748/9** are already done. It affects more that get left for long periods of time, if you are leaving it for a bit, fill it up with fuel !!!
