Fuel Relay problems
AndyP
Went to go out on the bike for a spin this afternoon and bike decided not to want to play out. :(
Fuel pump not priming and shows error 16.0 - Fuel Relay. As you'd expect it's cranking over fine, just not firing.
Read through a few threads and took off battery compartment and checked relay, didn't look corroded, but gave the electrodes a clean anyway - put everything back together and same problem.
Anyone know if any theres any other relays that fit? It's all together now and wanted to try and pick one up tomorrow. I'll try M&S first, but they usually don't keep the parts I need.
I'm hoping it's this and not the fuel pump - checked out the prices and don't want to sell a kidney.:eek:
think the headlight relay is the same, it is on the 749. worth a try, if it is its only a fiver fix:D
The fix for this is to put the new relay in a finger thats been cut off a latex or nitrile glove and fix to bike upside down so the terminals are to the bottom.
well picked up a new relay for £3.40 :) - fitted it tonight, but still no priming of the pump when you turn the ignition on :(
Now to start working where else to look....any suggestions would be more than welcome
And I should have said at the start it's a 2006 999s
My 999S went dead recently and wouldn't start.
Turned out it was a fuse blown in the rear-brake switch circuit which somehow cut the power to the starter circuit.
My thanks to Nelly at Cornerspeed for spotting that!
Start by checking the 20A fuse in front of the battery. It provides power for the fuel pump and the coils. If it is blown the pump won't power up.
If that's OK check the 3A fuse along side it. It is a permanent +12V to the ECU.
Also check the 7.5A fuse in the main fuse box. It supplies power to the ECU when the ignition is on.
The pump gets switched by the ECU, so if no power to the ECU then no pump.
The relay is switched by the ECU grounding the Brown/Black wire.
If the kill switch is off the starter won't operate but I don't think it stops the pump priming.
I hope that gives you some idea where to start looking.
Cheers Derek, so far I have checked....
20a fuse and 3a fuse on battery compartment.
Fuel pump relay doesn't seem to be clicking when turning on ignition.
Kill switch is definately in run position and engine turning over fine.
Not checked the main ecu fuse yet (my garage is round the corner from the house - with no heat or electric :(, and just got back in the house) - if the ecu wasn't getting any power, would I still get the eodb warning light on the dash, checked this again after replacing relay and still showing 16.0.
Although after checking the 3a fuse in the battery compartment, the warning light went off temporarily - still no whirring of fuel pump and the light soon came back on again.
Thanks for all your help guys, hopefully I should get it up and running again shortly.
I thought a bit more about this and concluded that for the ECU to throw Error 16 it must think the relay is either open circuit (disconnected) or short circuit to round (but that make it permanently on).
I think you will need to get a meter and check what's happening at the relay socket.
I haven't got the pin numbers but the 2 brown wires are fed from 20A fuse and are both +12V with ign on.
The Brown/White wire is live when the relay is activated and feeds +12V to the pump and ignition coils.
The Brown/Black wire goes straight to the ECU (Body connector pin 6) and is grounded by the ECU at ignition on, switching the relay on.
If you haven't got a meter the Brown and Brown/Black wires can be checked with a test lamp. An indicator bulb with 2 wires attached to it is ideal.
To test the brown wires: Connect one wire of the test lamp to the battery negative and the other to any of the brown wires at the relay. Switch on the ignition and the bulb should light.
To test the Brown/Black wire: Connect one wire of the test lamp to the battery positive and the other to the the Brown/Black wire. Switch on the ignition and the bulb should light for about 3 seconds then go out.
Good luck with it Andy. Error 16.0 is fuel pump relay disconnected. So I'd pay particular attention to the Brown/Black wire as it is the only wire connecting the fuel pump relay to the ECU.
Sorted!!
Massive thank you Derek, I sorted it out today and the bike is running sweet again :D
It was the wire from the relay to the ECU at fault, no reading when I tried it, disconnected the ECU and could see there was no continuity from pin 6 - traced it back to a nipped part on the wire and re-joined it.
All is good in the world now...without the help from the people on this forum, this would have taken me ages to troubleshoot, sorted out in under 2 hours.
Most likely the fuel pump relay. It's one of the 2 under the seat. You could also check the 5A and 20A fuses.
