Fuel drain on GT 1000
wolfie
This could be an easy task but in the event that its more problematic I thought I would ask here for any thoughts. So this weekend, all being well I will be looking to drain the fuel from my GT 1000 and begin the process of snuggling her up for the winter months. Does anyone have any hints or tips on how to drain the fuel or is it really that simple that this request is pointless??
Geoff
Check the underside of the tank first, there may be a removable drain plug, many Ducati tanks have them.
With the 907 and also when I had the ST4s I would remove the injection hose from the tank outlet and attach a length of hose taking it to a petrol can. Then by removing the pump relay and bridging terminals 30 and 87, when I turn the ignition on the pump runs all the time. A minute or 2 has the tank empty.
I think the 1000GT might have quick-disconnects though, If it does you'd need to buy a spare one and attach a length of hose to it. Fit it to the outlet and use the pump to empty the tank.
Alternatively if it's a metal tank you could just fill the tank to the brim and add a fuel stabiliser. If it's plastic it is better empty.
