Fuel cap
Phil_Superlight
Has anyone had there fuel cap off, ive had mine removed to replace the fuel filter and will it buggery go back on theres a green o-ring on the base for the fuel cap which feels a little slack could this be preventing me getting it back in place or are they supposed be a mega tight fit, ive tried tapping it back into place but it aint having it.
Phil.
Never had one off I,m afraid but from browsing the web I think they are quite a tight fit , Afraid the manual doesnt show it so no help there . Have you tried smearing the o ring with washing up liquid ?
Hi bud the o-ring is a tad slack which im presuming is my prob, the guy i bought my fuel filter off says stick it in the oven then put some vaseline on it but after been in the oven its still a slack fit and ive tryed knocking it on with a rubber hammer and it aint having none of it, i think im gonna have to try and get another o-ring from somewhere and try it.
Phil.
I don't have the same bike, but I've removed fuel pumps etc from 748-998 and 999 tanks and the o-ring is usually tight on there and it is a tight fit, they do slacken slightly and it's a real bugger to get the pump back in, so I would say your filler is pretty much the same and the o-ring has stretched.
You could try putting some grease on there and giving it another go, it'll have to be flat and tapped in centrally, any kind of side movement could pinch the o-ring which will need a replacement then.
Pump o-rings are around £7 so a filler should be less than that
How slack is it? The filler cap unit on a SS is a bit of a sod to get back in at the best of times. Are all the grub screws fully retracted? You could try the old bearing trick ie put it inthe freezer for a few hours which will contract the metal a little.
Hi guys ive tried greasing it up to get it to go in and gave it firm bats with the rubber mallet but it aint going (dont want to damage out) the o-ring when fixed to the cap, i can spin it round in its seat if you follow,i can grip it and gather up some slack, i thought theyd be a fairly tight fit but the guy i bought my spares of said there not :confused:
Hmmmm Cant find much on the web about it bar that they can be a sod to fit . Most say use plenty of vaseline , Just be careful with the old rubber mallet you dont want to end up with dented tank . Dont know if its of any help but "O" rings are something I fit a lot of at work for various jobs , usually high pressure valves and I tend to find that most will not just push in , You usually have to rotate and push down at the same time ,some times a judicious tap with the mallet as you turn the male piece , Sorry but thats about all I can suggest .
Hello I guess we are talking about a superlight tank here which is the same as a ss tank. I have removed and refitted the cap many times on my ss and all I have ever had to do is give it a firm push by hand. If you have removed all the grub screws and lubed the o ring and it still won't go in, then you need a new o ring. Hope this helps.
Im going to have another go later, ive sent the mrs out for some vaseline ;) so i can get it well lubed up before i try to slide it in, if i cant get it in with it been to big il be gutted as ive been gagging for a ride all weekend :D
Hi bud yeah its the superlight tank, all the grub screws have been removed, i lubed it but didnt absolutely cover it and it wont go im going to have another try later, i think the o-ring is to slack as when its on the base that goes on the tank if i pinch the o-ring i can gather about 15mm of slack.
Black 900 said:
sounds like your going to need a new o ring
Hi bud ive ordered one but it aint gonna arrive to the dealer til the weekend then hes got to send it to me :( looks like i wont be getting out for a ride for a while
:( No, me and bikes dont seem to get on, my first bike in july of last year was a 600 ninja and had no probs with it but got board quick so i bought a gsxr750 srad which was fine when i got it but the choke liked to stick on and revved its bolox of when started, so i bought myself a 650 husaberg and nearly dislocated my knee trying to start it so it had to go, then i got the superlight which goes for about half a mile then i have to push it the rest of the trip :) but i really like this bike so its staying :D
