Just purchased my own motorcycle workbench. It’s the electro hydraulic type and I’ve got some upgrades in mind with my waiting on delivery rf 4 channel momentary switch unit. Up down movement of lift for two channels.
For the other two here’s the design for my fully automated front wheel clamp. There’s a 12volt dc motor supported by the outer shell. At the centre of the shell is a rotating ballscrew fixed to the motor. The ballscrew is protected from dust etc by the shell and is fixed to the pushrod(basically nut) that connects to the vice. Two linear bearings complete the design and coupled with the drive almost friction free movement. Simple miniature pressure pads as found in car seats will complete the design. In theory should work well. My software allows me to animate but this s a snapshot.
I’ve never liked the automated front wheel clamps that you push the bike into. Probably ok for some bikes but ones with long mudguards get damaged when it flips up. With my arrangment place bike on lift and simply press remote switch to activate motor. There are hydraulic versions available but I already have motor and ballscrew. Linear bearings and rods not to expensive. For the side plates I will design and generate a dxf file and have them waterjet cut. Here’s hoping my TIG welding course provides me with the ability to weld side plate support and bearing housings.
