Front suspension soft
ian900ss
I heard on another Ducati website :eek:, that u can change the front springs if you are a heavy get, any one done this?
I have changed the springs in the 1098 forks on the Supersport project as it's lighter than a 1098. It's well established that OEM springs are designed to an 'average' weight although I have found the SL to be on the stiff side and am no anorexic.
Changing springs in my Thruxton transformed the bike. It's a (relatively) cheap mod, and easy to do.
You need to make a wee tool, or I can lend you mine.
http://www.ducati-upnorth.com/forum/showthread.php?11851-Project-Superspurt&p=221712#post221712
tinker with the preload first to see if the springs are wrong
get a tie wrap and tie it round your front fork stanchion..then go for a good run...with hard braking and see where the tie wrap ends up when you come in from your run
what your looking for is almost full fork travel when braking i.e.the tie wrap towards the bottom of the stanchion...adjust the prelaod until the tie wrap is about 10mm from the bottom of the stanchion..if if the forks are continually bottoming out then they are to light so get heavier ones..or if you cant achieve full pork travel then springs are to heavy and lighter ones needed...
