Front sprocket ....
CJK
....there's a wee bit in and out movement on the shaft,the sprocket waggles a little probably no more than a mm is this norm.
Yes, the sprockets get a bit loose on the shaft after a while but take off the retaining plate and have a look at it. Some of them have been known to wear through!
do that when she goes off the road end october,plan on replacing chain/sprockets anyhoo...thanks Derek
I have replaced the 'splined retaining washer' on the Imola, tis cheap if the sprocket isn't worn out. There shouldn't be any movement in the shaft though. :eek: That, unfortunately, is a crank split jobbie to re-shim the shaft. How much movement is there? if its a knat's c0ck, don't panic about it, if it's half-a mill, I would worry about it. :)
I have replaced the 'splined retaining washer' on the Imola, tis cheap if the sprocket isn't worn out. There shouldn't be any movement in the shaft though. That, unfortunately, is a crank split jobbie to re-shim the shaft. How much movement is there? if its a knat's c0ck, don't panic about it, if it's half-a mill, I would worry about it.
Sorry not very clear the way i worded it,tis just the sprocket on the splined shaft that moves a knat's c0ck.
Thanks for the offer AndyI'll keep that in mind nearer the time,the teeth on both the front and rear look fine,but the rear sprocket and chain dont visually look the best,t0sser i ken but i like a clean looking rear sprock and chain:rolleyes:
I think the sprockets meant to have a little sideways play in it to be able to align itself on the chain, disconcerting when you first notice it but otherwise normal I think.
Front Sprock
Dave, a guy I was talking to recomended a 14T front sprocket for the SC to make first more better round town and 6TH a bit more usable colser to legal speeds.
Ever contemplated this?
...Oh right, that's ok then. Yes there should be a small amount of play in the sprocket. :)
I had a 14t front fitted before I even rode the bike, I've done every Ducati I've had and all of them have been better for it.:)
Same here, one of the 1st things on all of my Ducatis has been to put a 14t sprocket on. An easy, popular and cheap modification that improves the way the bike rides :)
Me too, but when the chain needed replacing I went back to 15 and up 3 teeth on the rear sprocket. It gives the chain an easier life and it doesn't wear so hard on the rubbing block on top of the swinging arm.
AAWWW F.F.S.:eek: I hate different options :dunno:
here's another one :D
I had the 14 on, which was good for the twisties and city riding, bad points, increased fuel consumption (i did alot of miles on the bypass), on long straight(always private roads or circuit riding :rolleyes: ) once you reached 120 that was it, if you pushed anymore, the engine felt like it was going to explode. So i ended up going for one tooth up (38 i believe) at the back and 15 at the front, which wasnt that bad but still good enough for 130, if you're going to do alot of long distance travel, i would leave it as it is , on the other hand a 14 at the front would help with your speed paranoia :D ,
...you could always tune the motor like I did and leave the gearing alone - same affect!!!! :p
Colin tell you what mate,come round and get the 14 fited, get a feel for it for a few days, if you like the way the bike goes whith it, you can keep it mate is nearly new:thumbs: , it will cost you dear though :D
Colin tell you what mate,come round and get the 14 fited, get a feel for it for a few days, if you like the way the bike goes whith it, you can keep it mate is nearly new , it will cost you dear though
might take you up on that Mafi son;)
or just save up for a 916,try to keep up with the big boys eh :D
...you could do I suppose, but I know of one of these motors that regularly keeps up with 916's and the like.... :whistle: ;)
...if that's yours in your avatar, tis a fine specimin sir!! :thumbs:
it is mine thanks :thumbs: So what's the secrets to fettling these motors then ?
...Surprisingly little really;
Imola has:
Arias high-comp pistons £££!!!, lightweight flywheel, lightweight clutch basket & clutch pack, lightly ported heads, High-flow oil-cooler, Keihin Flat-slides (that are still not on coz I've just bought a 748SPS!:rolleyes: ), Silmoto 'Nest-of-Vipers' down pipes (larger diameter but can't remember how much) and bolting it to a lighter weight chassis.
It doesn't make masses more power (about 90 odd) but it makes it in a very nice way!!! :)
