Frame repair?
hindsight
Well-known member
... and before anyone asks, no, I haven't had a whoopsie :), but I was looking at a bike earlier. One of the frame struts has suffered a bit of a blow when it was dropped, and as such that section of the tubular frame has got a bleedin' big ding in it.
It's just a ding, rather than a crease, but it is a good 3mm deep or so and I wonder about its' strength after suffering a blow like that.
A question for those that know... is this likely to be a fatality for the frame?
I suspect I know the answer already, but thought I'd throw the question open to the panel...
In my opinion the frame will be fine, unless the ding has altered the geometry. If in doubt get it checked. Otherwise, fill the dent and re-paint it.
I tend to agree with Big D. It's steel after all. It could even be pulled and plug welded but that's more difficult in situ.
I would think it is fine as well and having done some work on the frame for my project bike, the modern trellis frame is probably over engineered.
However if you were not sure you could cut out the offending spar and weld in a new one.
If it is a bike you are looking at to buy then obviously it has a HUGE impact on it's value! :lol2:
Non ducati;)
