Fork Oil Air Gap
Pict
My previous forays in to forks have just been straight oil change - add the qty in the manual, or seal replacement and re-fill. I have been advised alternate settings, oil weight and air gap for the Superspurt project and I know that you measure the gap with the outer fully depressed and the spring in, but am I measuring gap to;
1. Top of the (outer) fork leg
2. Top of the (inner) stanchion
Fork Strip 4 by Lindsay fae Angus, on Flickr
top of the outer, fork gap measuring tools usually have a collar that sits over the outer and a pipe that goes through the collar, you measure the distance from the end of the pipe to lower face of the collar to set the air gap, you then use a syringe to suck out excess oil
I saw in the Heinz manual that they removed the spring and nylon spacer prior to measuring the depth of 108mm and 440cc of oil but that was on the 620 forks.
Cheers - I've seen these tools but wasn't sure whether they sat 'on' or 'in' the fork. They are quite dear for the amount of use it will get, so was going to go for a crucifix comprising bit of wood, steel rule, duct tape or tyraps then just add a drop at a time as the level reaches the bottom of the steel rule. If that is a PITA then I might have a go on the lathe at making one of those tools, I bought a 5 pack of syringes a while back for reverse bleeding the brakes on something, possibly it was even the SL so must have one somewhere.
Thanks Sam, but I have been given an air gap 'with spring in' to work with. This is for resprung 1098 forks on a lightened 900SS :cool: so it's all a bit rule of thumb.
Are you sure you want the spring in? With the spring in and the forks fully depressed the spring will stick out the top by a fair bit.
From the1098 manual:-
Front fork for 1098 only - SHELL Advance Fork 7.5 or DONAX TA - 0.511 dm³ (litres) (each leg)
Front fork for 1098S only - SHELL Advance Fork 7.5 or DONAX TA - 115 mm (each leg) oil level height
It doesn't say spring in or out but it's usually out. It is for the other models I've seen.
Derek, Sam, you are correct, it's spring OUT :o
They don't stick out though, they aren't that long;
Fork Strip 3 by Lindsay fae Angus, on Flickr
refer filler caps in top of picture for scale.
In my application, with these springs, am advised 5W oil, 125mm air gap reducing to 110mm if necessary.
