Fitting HID lights to a 1995 748
Not a 748 but have done on an ST4s, MTS1200 and the 907ie. Easy if you know what your doing :D
Worth it? Definitely. Especially on the ST4s which uses the same dismal projector unit for the dip beam that the 748 does.
I've had perfectly good results with cheap Chinese ones of eBay.
Don't bother fitting them to the main beam unit. They take a few seconds to get to maximum brightness so not too good for main beam that gets switched on/off a lot.
Go for 4,300K colour temperature. The higher the number the bluer or even more violet the light. Blue is good for being seen but not good for seeing with as your eye is more sensitive to yellow. 4,300K will also best match a halogen main beam for colour.
The trickiest job is finding somewhere to mount the ballast, fortunately the newest generation of HID ballasts are much smaller and slimmer than the 1st generation ones were.
And use a relay, switched by the low beam feed, to supply power via a fuse to the ballast. The start up current is quite high, in the region of 10 - 12 amps but drops off rapidly to around 3A. Any more questions just ask.
Thanks Derek
Much to think about, especially is I have the ability to fit them ! You scared me with relays, etc etc
How long would they take to fit ? What would you charge :) your only up the road :)
Silver-Surfer
