Dodgydave78
Things have been going well with the S4 until today when I was stranded due to an electric issue. It had been tricky to start with the dash lights flickering and and bike cutting out (like a loose connection. Before I go stripping things down and checking wiring etc is there any common causes for this on the S4 ?
Best way to describe it is like there is a loose connection in the ignition barrel. After walking the 2 miles home It fired up and ran for 30 seconds and then cut out. Now it wont start and the dash lights are only coming on intermittently.
I'm thinking moisture due to low temps etc which may be causing a short?
Any pointers would be greatly appreciated.
Thanks
Dave Russell
Thanks
Dave Russell
