Faulty GPS or electrical problem
Gizmo
Forum Geek
I've had the heated jacket wired to the multi for a few weeks and now that I'm using it, heated grips and GPS all at the same time the GPS display has started dimming then switching off as its battery flattens even though the indicator shows its charging. Jacket and grips are only on their low settings so it shouldn't be using that much of the alternator output ( i think). GPS only goes flat when ignition is on ( its wired through the switched socket) which leads me to think the alternator isn't providing enough charge so it starts to draw from the GPS unit battery, is this possible or have i just got a faulty GPS?
Is the GPS battery also 12V and simply paralleled to the bike when the ignition is on? If it is I'm surprised, but in that case it would discharge down to the bike's battery voltage but no lower.
Try connecting a voltmeter to the bike's power outlet. Note the reading with the heated grips and waistcoat switched OFF. You should see at least 13.5V with revs over 2K, probably more than 14V. Switch ON the grips and waistcoat and see if there is any change. If the volts drop to less than 13.5 it is struggling. The GPS current draw should be negligible and I would expect it to have little effect on the battery load.
Battery spec from Garmin site
Input: 5 Vdc
Usage: 6 watts maximum @ 13.8 Vdc
Battery: Rechargeable lithium-ion
i think its parallel its just plugged into the heated grip socket, it only seems to do it on the bike not in car but they use different connectors/bases. i'll try and blag a voltmeter to test it all.
Input: 5 Vdc
this is gods way of saying "too many gadgets" :lol2: :lol2:
Since the GPS battery is a 5V Lithium-Ion it must be charged via constant current charger powered by the 12V supply from the bike. The charging circuit would effectively block the bike from discharging the GPS battery so I don't think that's an issue. First thing to look at is whether there is 12V coming out of the socket. Is it fused? if so is the fuse OK?
