Hi All
I have an 848 that has a cyl that cuts out from start up, the engine keeps going from 1 cyl to two. Any ideas ? how do i test the coil and what should i get re ohms etc.
Thanks
Check which cylinder is cutting out - it's exhaust pipe will the cooler one. Don't burn your fingers
Then swap the coils between the cylinders. if the misfire swaps to the other cylinder it's the coil. If not it's something else.
Out of interest - does the ecu record a fault code for this sort of thing, and can it be read with ducatidiag? - I had a failed coil on my Benelli last year, and hooking up the laptop helped to track it down to exactly which coil had the problem.
