Extreme overheating one cylinder
Bajabound
Hello.
II've tried searching this problem here and other places but still am confused about what Is going on with my bike. A little background....I am rebuilding a Cagiva Gran Canyon, which has basically the same motor that powers the year 2000 SS900 (900 cc, fuel injected, 2 valve). I have reassembled the bike from two different Gran Canyons (long.story), using the best combination of parts from the two bikes.
My problem is that the vertical cylinder runs super, super hot. I mean that within 5 seconds, the exhaust pipe is smoking, the heat and smoke quickly moving up the pipe toward the muffler. I have ruled out the following by switching each variable to the other cyclinder and every time, the same result - extremely hot vertical cylinder:
Plugs (gaped and show blue spark)
Coils (noticed that each is specific to vertical and horizontal cylinder.
Coil wires
Injector electrical connection
Also have checked the following the verify equal for both cylinders:
Injector function
Compression (both more or less are 120 psi, which I don't nthink is too bad considering I am at 5400 feet and the engine is cold when I do the test.
I am pretty sure the major cause is valve clearance and possibly valve timng. This is because I switched shims between the two cylinders and now the horizontal cylinder is super hot, seconds after starting. This seems to suggest, at least in part, that the overheating is due to incorrect clearances. The.compression also dropped on that cylinder to 90 psi. As far as valve clearances, I am starting from scratch, so I have no reference or starting point other than where I am at this point in time. I am somewhat confused about what values to use for "ideal" clearances. It seems to me that every bike is potentially different.
1 . What ideal clearance values should I use as a starting point? The bed I can determine is .003 to .005 for openers and 0 to .002 for closers, though I've seen higher values quoted.
A. Intake opener
B. Intake closer
C. Exhaust opener
D. Exhaust closer
2. What is the predicted affect on compression as I stray from these ideal clearances for each of the following valves? (Tighter/less clearance or Looser/more clearance)
A. Intake opener
B. Intake closer
C. Exhaust opener
D. Exhaust closer
3. What is the predicted affect on combustion ((leaner, richer) as I stray from these ideal clearances for each of the following valves? (Tighter/less clearance or Looser/more clearance)
A. Intake opener
B. Intake closer
C. Exhaust opener
D. Exhaust closer
Also, I read the piece from Ducati Up North on Cam timing (Cam timing - Ducati Up North). This helped me understand the timing issues of the four stroke cycle . I don't think my extreme overheating problem is due to cam timing because the crankcase I'm using came from a bike that ran fine. I assume if my problem was cam timing, it would have appeared beforehand but not sure....?
Maybe I need to verify with a degree wheel though it seems there is variance en the crankshaft rotation degrees for different motors...?
If there is a kind soul out there who is willing to take the time to explain any of this, it would help me immensely, and hopefully, others as well.
Thank you.
Cheers,
Tony
That's one hell of a lot of questions.:eek:
I think you have really answered your own question. When you moved the shims from one cylinder to the other the symptoms moved with them. So clearly they need setting correctly but the shim requirements for any one valve/rocker can be and most likely will be completely different for all the other valves.
120psi seems low but atmospheric pressure at 5,400 ft is only just over 12 psi so they are probably good. But for the cylinder that is overheating, dropping to 90 psi suggests that the exhaust valve isn't sealing and may even be being kept off it's seat. This can happen if the closer for the valve is too loose and the opener is too tight.
The ideal clearances for your engine are :
inlet openers = .004" (permitted from .002" - .005")
exhaust openers = .005" (permitted from .002" - .006")
all closers = 0.002" or less (permitted from .0015" - .008")​
When checking the closers make sure that you can rotate the shim while pressing down on the closing rocker to take up the closer spring pressure. If you can't rotate it, it is too tight.
If all the dots line up when the engine is at the timing position, dot on bottom pulley lined up with line on clutch side cover then your timing will be fine.
Thanks for the advice, info, and suggestions. I've managed to get the clearances within the ranges you recommend. Also, the compression is back (leaky valve). Part of my confusion about overheating was I had no idea that out of spec clearances could result in such extreme conditions. I hope to get a chance to start the bike up tomorrow and see what happens. Cheers, Tonym
Thanks for the suggestions and info. I am trying to get the.clearances as close to ideal as I can for the moment, based on the available shims I have in my shim kit. One thing that had me confused is I had no idea that out of whack clearances could cause such rapid and extreme over heating. One other question I have is: As I am trying to fine tune clearances and given the choice between a more "ideal" clearance and a higher compression value, which should I choose? I would think compression but want to confirm. Thanks, Tony
Here's a perplexing situation (at least for me) that just arose.
Went to start the bike and during part of the crank cycle, the starter really struggles. The cams are not binding and the time belts are adjusted. It only happens when the spark plug is in the vertical cyclinder. If the spark plug is not in the cylinder, the horixontal cylinder wants to start. Wondering what is going on. It feels like extreme compression, not physical obstruction. Never experienced this before and wondering it is connected to my overheating problem or ...?
As long as the shims are within the range specified and the valves are sealing there will be no change in compression.
I'm back at it after a brief hiatus. I went back over the assembly and checked that all cam timing marks were aligned. Compression is still around 115, in both cylinders. Currently, the bike starts but now, both cylinders heat up rapidly, such that within 20 sec, both tailpipes are smoking hot where they exit the cylinder. I am beginning to think the problem is related to ignition timing. At the moment, my spark color is not the desired blue that I have observed in the recent past. Also wondering if it could have something to do with a malfunctioning or bad crank sensor. I remember seeing a YouTube where the person demonstrated how finicky Ducati crank sensors can be by showing how resistance fluctuated by just tapping on the sensor. Does anyone have any experience with diagnosing, repairing, or replacing sensors and/or coils? Do I need a Mathis diagnostic tool to check the actual timing of the spark plug firing? I appreciate the continued support and advice.
My first thought upon seeing your post is that the ignition timing is out. I don't think that a weak mixture will cause overheating as quickly as you describe, it usually shows up after the bike has been ridden. I would guess that you really need to get the bike to a Ducati tech so that they can give it a full check over on the diagnostics computer.
It might be your perception of what's overheating, hope you don't mind me saying. My Multistrada (air cooled) will quickly have the down pipe from the vertical cylinder slightly glowing red and there's nothing wrong with it. I've set the clearances, changed the belts and synced the throttles (cylinders really).
It did concern me also I even pointed my infra red thermometer at the pipes.
I also think that it appears to be an ignition timing issue but of course with the fuel injection there is no adjustment, it is entirely determined by the ECU based on the signal from the crank sensor and TPS.
In my experience, normally crank sensors either work or they don't but sometimes they work fine until they get hot, sometimes they don't work beyond a certain rpm but recently I came across a case on an 1100 MTS where the sensor did appear to affect the ignition timing.
The owner was riding the bike when it suddenly lost power but he was able to ride it the few miles home albeit at a very reduced speed. Thereafter although the bike would start it was running very badly. I connected a diagnostic software but no DTS errors were found indicating all the sensors were apparently OK. Since a spare crank sensor was available we changed it anyway and to my surprise the fault cleared and the bike ran perfectly. So although the crank sensor was providing a signal there must have been something wrong with it that affected the ignition timing.
The crank sensor is the same as that fitted fitted to many Fiat cars, including the 1.2L 8V Punto although I don't know if these are sold in the US.
For diagnostics your best option is probably JPdiag. It is free but you will need a couple cables. It is documented on the website which is largely in French but Google Translate works quite well.
Thank you Derek, for the link to JPdiag. What an incredible resource for the DIY Ducati owner. I ordered the cables today and will report back what I find. Thank you again for the help and suggestion. One comment regarding what I am referring to as overheating. Within 5 to 15 seconds the tailpipe is smokimg and extremely hot to touch. I've seen this motor run before and witnessed nothing remotely similar. Finding it hard to believe that this extreme temperature could be normal. Thanks again!
Another possibility is that the TPS setting is way off. Lets wait and see if the diagnostics turns anything up.
