I
iang27
Just visiting
I have just fitted to my 1098 an EVR slipper clutch as per the supplied instructions, Spacer with 'O' ring, Basket, Centre Hub, Bevel Washer, Nut torqued to 200Nm as instructed.
The plates were fitted exactly as they were supplied (In correct order)
These clutches do not use the ball & ramp design, they use a centrifugal type of design, something new.
When I start the bike the pressure plate spins and when I pull the clutch in it pushes out a couple of mm. When the bike is put in to gear the pressure plate stops completely and cannot be moved at all by trying to turn it with my hands. When the bike is on the paddock stand and in gear the rear wheel spins quite quickly even though the clutch is pulled in, it can be stopped but it takes some pressure to stop it from turning.
I 'seems' to clunk a bit more going in to first gear now and neutral is harder to locate.The gearbox does not feel as smooth as with my other slipper clutch.
I took the bike for a quick spin and it 'feels' like the brakes are on (I know they are not obviously), as soon as I back off the bike slows down quite quickly which it never did before.
With my previous slipper clutch that I have just removed it still spun until put in to gear then the pressure plate spun slowly and could be stopped with one finger, the rear wheel did not turn at all if the bike was in gear and the clutch was pulled in.
Could it need a plate removing or adding, is it just the new clutch plate pack not bedded in yet ??
Maybe these clutches allow more engine braking compared to a standard ball & ramp clutch and it is just this that is making it feel as though the brakes are on, Anyone any idea ?
