engine paint
mk1golf
Hi, this may sound like a daft question but what is the best way to paint the engine while in situ ie: is there a certain type of paint and how have people gone around doing it.
I've seen online some people remove what they can and mask up and spray and I've also seen people hand paint them.
thanks in advance
See bottom of page 1 on the link to @Chizel - Founding Father 's build, it may help you decide to take the engine out which would be easier in the long run.
Use etching primer before paint.
I painted my 996 motor while in the bike, i took off what i could wet and dried the motor then spent a 1000 years masking off!! :) I used Simoniz Aluminium Matt Engine Enamel, it came up really nice.(y)
That's great thanks. it looks great
Thanks for the link that build thread was great.
thanks in advance
On the block, any decent 2k paint should be fine, it can handle the heat. I’d use a wash etch as opposed to a higher build, wash etch is about 10 microns when dry, the higher the build the more chance of failure due to heat. If you’re using a clear, use a 2 part, not single. Being a chemical cure, it’ll hold up better to solvent. Sikkens have a great aerosol wash etch
