Engine oil
853RS
My ST4S has the later wet type clutch and would like to know if I can use full synthetic oil,my previous 748 and 916 I always used 10/40 full synthetic but they had the dry clutch.I have heard that full synthetic can cause clutch slip.
In my opinion there are a lot of myths about this. As long as you use a motorcycle specific fully synthetic oil it will be fine. Car oils have friction modifiers added which will cause the cutch to slip.
Ducati recommend Shell Advance Ultra 4 10w40. It would be a somewhat retrograde step if by fitting a wet clutch it required a lesser quality oil that compromised the lubrication of the engine.
