Electrical connection assembly
wheelybin
I purchased some of these from fleabay B00D77SRZS ( 2 pin electrical connectors), to provide a secure connection to my optimate, its frustrating when you find the battery hasn't been charging over night as it should have been. ( Jacket and helmet off, find car keys, off to work 15 min late....) Despite searching, I cant find any instructions on how to assemble the connector, anyone any ideas???
A picture would help or a link to the eBay item. B00D77SRZS doesn't return anything sensible on eBay.
That's better, Superseal connectors. I just put together a few score of these last week.
You fit the seal on first over the insulation. Then bare the end of the wire and crimp on the connector. It might be possible to solder it on but you really need the right crimping tool. If there is any excess solder or bits of the terminal that would normally be crimped sticking out then it won't fit into the housing.
Once the terminal is on you push it into housing until it clicks into place. When all the terminals are inserted into the housing push the red plastic bit fully down and it locks them in place. Then push the seals in from behind to waterproof the back of the connector.
Here is a PDF about how to assemble them;
Or, buy a motobatt battery. My S4 turns over 1st prod when in regular use and 2nd/3rd over winter when I only get out every 2-3 weeks. I don't have access to power in my garage so charging not an option. Before the Motobatt I had to remove my battery and bring it in the house to charge up overnight.
usually had no probs starting, just in winter when its left for a couple of weeks. Extension lead and 4 hours charge each week end helps. Big thanks to Derek for the distructions. :cheers:
If you don't have the crimp tool then it can be done using some long nose pliers. I would recommend soldering the wires in the connector as you will not be as secure as the crimped ones. Or, post the wires to me and I'll crimp the connectors on for you.
One like this?
