ECU Help!
ecurie ecosse 900
I've just got hold of some secondhand Ducati Performance cans, they came with filter, airbox cover and ECU; everything fitted easily until the ECU was plugged in. When I turned the ignition on the fuel pump buzzed into life but run continuously and starter wouldn't turn the engine over. I swapped back to the standard ECU and everything was back to normal.
Both units are marked IAW15M.A8; I've just found out that the previous owner had it fitted to his 1999 900ss, mine was manufactured in 2001, is this the likely cause?
Anyone got ideas? I don't want to run the engine lean.
Craig
How I understand it - the ECU will have been 'mated' to the previous owners bike, so it is a one hit wonder, once fitted, unless you have the red key and ignition the ECU thinks it is in the wrong place and will not work, its useless.
As I say thats how I understand it, so options are, fit cans and get the bike on a dyno with a Power Commander fitted, or take it to a dealer and get it checked out and adjusted.
HTH
The immobiliser function with red and black keys didn't appear until the 5.9 ECU was fitted to Ducatis around about 2002, so it's not that but there must be something else that is different between the 1999 and 2001 models. I'll see if I can find anything.
Thanks guys, I'll phone Ducati Glasgow and Injection Correction tomorrow, failing that I might have to go for a Power Commander; are the older MK2 versions any good or am I better going for the MK3(USB)?
UPDATE....... I spoke to Ducati Glasgow today, there appears to be a couple of ECU's for the 900ss; one is for the 1999 bikes and another for 2000 onwards. Apparently if you buy a new performance kit its no longer supplied with the ECU; you keep the standard unit and have emissions adjusted.
BTW Injection Correction said they could fit the ECU for £190 but didn't know anything about model compatibility.
