Andy,
I found the Factory pro kit worthwhile and can give you the settings I used but I have no experience with the Dynojet.
When I had the SS I did a fair bit of research before deciding on a jet kit. Reading US based forums, the consensus appeared to be that the Factory Pro kit was better than the Dynojet one. Perhaps the only reason being that Factory Pro use the same jet numbering sizes as the OEM Mikunis whereas Dynojet use their own numbering system which has no reference to anything else.
If you do decide to fit a jet kit make sure that you fit new emulsion tubes (needle jets) as well, as the ones in the carbs will almost certainly be worn.
The Factory kit consisted of 2 pairs of main jets (both oddly, smaller then the OEM 140s), a pair of needles which have a very different taper from the standard ones, 2 springs and a pair of #40 pilot jets which you won't need since these are aimed at the Californian market which had very lean pilots fitted as standard. Also a set of socket cap screws to replace the crosshead ones that you will probably mangle up when trying to take the carbs apart.
The kit comes with recommendations for use with original filter/airbox and standard cans, original airbox/filter and race cans and open airbox with race cans. There are no Stage 1 and Stage 2 versions.
The biggest improvement was to the midrange and throttle response, and after fitting new emulsion tubes the carburation was as near perfect as it could be with the bike actually running leaner throughout the whole range and usually doing better than 50mpg.
