853RS
I have had a few Ducati sprag clutches to change over the years and have found that the main problem is the retaining spring for the rollers.It is a bit weak and over time it stretches and causes the sprag to stop working.Some people cut a small section out of the spring and reuse it.I have found a stronger spring fitted to an SKF oil seal which is the same dia but a lot stronger.The oil seal is about £8 so a big saving on a new sprag.All you need to do is fit the spring and get some fine wet and dry and give the outer bearing face a rub with the wet and dry and some paraffin till nice and smooth.100%success rate up to now.
The same sprag is also fitted to KTM,BMW and Aprillia v twins.KTM price is about half the Ducati price.
