HootOwl
Well-known member
I recently discovered that the fuel pipe clip on my Multistrada fuel tank/cap is broken, a previous rock ape obviously didn't unclip it properly when they removed my tank.
The bike was in at Cornerspeed and lucky for me Nelly managed to get it all back together successfully, but also told me the clip is part of the pump and not available separately. Had he not been good, I would have been stuck.
It is crazy that a part that seems to break so easily and so often, is unavailable from Ducati this side of a new fuel pump, but trawling the web reveals that all may not quite be lost:
Moto Guzzi use a similar type clip on some of their two-wheel tractors I found.
I ordered a couple from Stein Dense in Germany and after some skilful work, managed to extricate the clips, from the black connector (that is no use to us) by using some thin plastic strips cut from a spray cap, carefully slid behind the tabs to allow removal. They are still fiddly to get off though.
So, the next time the cap or tank needs to come off young Muttles, I guess I will replace the dodgy clip I have. The attached shows the relevant part numbers to order and how the clip we want looks when removed from the connector we don't. Not cheap - but cheaper than a new pump
I now have a spare grey clip taped to the fuel sender just in case. The other I bought will reside at home.
