Ducati brake fairies
239desmo
Is it nearly bedtime?
Trying to get 748 back on road in time to meet up with troops heading North this weekend found rear brake binding. Being of restricted mechanical abilities (and intellect) several cups of tea were consumed sitting "studying" the offending caliper deciding if 1. I knew what I was looking at , 2. did I have tools to sort it and 3. did I really know how to sort it.
After much deliberation decided on removing caliper. Must be a fairly safe bet I thought. Bit of a job getting the right length of bar on socket to reach bolts without fouling wheels etc but amamzed myself that not only did I have a socket that fitted but bolts came out easily. Proceeded to work the pedal gently whilst wedging a large screwdriver between the pads and all seemed to work smoothly. Reattach caliper and decide that as it's now almost midnight time to call it a day.
Next day take bike to work and decide not to use rear brake as binding brake 20 miles from home is not the best plan. Coming home at night come up to house and think well let see if my handywork has achieved anything. Step on the pedal and pedal drops so far that it fouls the fairing. Braking effect was minimal.....well actually zilch to be precise. Spend a few minutes "pumping" the brake to find there is still nothing happening. Push bike into garage and go for my dinner. Finish dinner and take cup of tea out to garage and resume "careful studying" routine. Decide that this suggests either no fluid or air in the system. New cup of tea and think air in system more likely as no evidence of fluid p!ssing all over back wheel. Take top of reservoir and lots of fluid to be seen so now deciding that air is the villian and feeling quietly confident in my new found mechanic skills. Bleed brakes I think. Will need a tube or something to attach to nipple. (Bike's not mine) Where do I find that.Hmmmmm.........another cup of tea whille I rummage through garage trying to find something that would fit. Battery fluid bottle has clear tube attached and now I am really getting cocky! Go back to bike with tube in one hand tea in the other and sit down to plan the next move. Think that I'll take the top off the reservoir and see what happens when I push the pedal as that may give me a clue what is going on. Ok it never was going to but seemed like I was doing something constructive. Watching fluid level I push the lever and .......pressure back in the system and back brake operating perfectly!:confused: :confused: :confused:
Now apart from having my dinner and looking at the bike I didn't actually do anything.
Conclusion?......the fairies visited whie I was eating and sorted it, or I had a dream about brake failure.
Only downside was I spent the whole night getting up to go to the loo having consumed so much tea.
Now hoping they visit soon again and replace valve stem seals on the bevel twin and solder up the wiring at the same time.
If I can catch the fairies I will make a fortune renting them out to you lot.
Can just see the website now....www.rentafairy.com
Can't imagine that anyone else would be using that web name!:D
I won't be typing it into my computer to find out though...;)
AAH! brembo rear brake master cylinders, they haunted you know!;)
It might be binding rather than your caliper, the pushrod get all rusty etc and sticks, on or off. I've replaced a couple of them but I'll wager that yer problem. Start trawling ebay theres plenty around,I dont think they're too dear from new though,about thirty pounds sticks in my mind....perhaps cheaper.
Wd40 won't sort it you reckon if it is the pushrod combined with a good clean?
Had the same problem myself last year.If you remove the dust seal there's a circlip behind it.Remove that and the piston should come out.Give the piston and inside of cylinder a good clean with meths.Lubricate the seals with a wee drop of red rubber grease reassemble,bleed,and hopfully youre problem is solved.
Ranald
Ranald
:thumbs: :thumbs:
Wondered where I'd get some meths then I remembered there was a squad from the South heading this way.....law of averages says there must be one weagie in there that would have some with them......that's assuming Davie has not become too desperate and polished that off as well!:lol2:
If you catch it early enough perhaps,I dont know enough about that scenario, but mine had ripped the seals or had allowed the air in somehow and were gubbed after that as brembo dont make overhaul kits anymore.
Brake dust builds up on the piston and as the pads wear down it then gets forced behind the rubber seal and into the chamber, hence binding.
Take caliper off, and pads out, move piston out as far as you dare and clean the piston with brake cleaner and a piece of abrasive plastic, grease them and put em back together, do this every 1500 miles or so.
Stewart, you will have to cable tie the caliper so it is higher than the reservoir when you bleed the brake or else the air will get trapped and it will never bleed properly.
Starting to think not using the back brake at all is an attractive proposition!
Thanks guys for all of the above so far.:)
I only ever use the rear brake on the Cali for keeping the front wheel on the ground out of corners!!!!!:D :D :D
difficult really with linked brakes!! :p
I will try that one sometime, I'm sure it would be far more comfy too!!!! :p
right, horses to ride now ....:eek:
