Crewy05
Hi all, as the title says, have a starting issue with the bike. A few weeks back i went to start the bike, i hit the starter button, and the bike started to turn over, all be it slow, i took my thumb off the starter button and the bike kept turning its self over! Only way i could stop this was to take off the battery lead. Didn't have time to look at it so left it a few day.
When i came to look at it, the starter solenoid was clicking, the issue seemed to be pointing to the starter motor, so took it out and as i unscrewed the rear cover, oil poured out of it
. So i ordered an new shaft oil seal and after much arguing with the guy at Ducati Bristol a new brush motor kit (which he was certain Ducati do not do) oh how he grovelled to me when he found out they did!
So all new parts fitted, engine put back together i press the starter button, but nothing! After some playing about the starter motor managed to make a small movement but nothing to turn the engine over. So out comes the multi meter and the rear starter motor cover comes off, i have checked and double checked everything i can continuity wise that the haynes manual states, and everything is fine. Now here is the confusing bit, the solenoid click, it shows continuity between terminals when the starter button is pressed, it shows 12.7 volts off the lead from the battery, and red wire on the electrical plug on the solenoid shows the same power when button is pushed. with me so far??
Now when i check for voltage on the starter motor side terminal on the solenoid, once the button is pressed i get nothing, and, there is no continuity from the end of the starter motor wire and the battery lead terminal on the solenoid. So to me I need to but a new solenoid as im thinking its not making a good enough connection to send and voltage down to the starter motor?
What are your thoughts?
