Ducati 888 engine rebuild 2
fatirossi
Found out that the con-rods were bent, but managed to locate a pair of as-new H-beam steel Pankl conrods from an AMA 851 racebike off a guy in the USA who got them given, so he's being very honourable and giving them to me for nothing. Only costing £25 P&P for the pair.
Crank case split and the crankshaft fitted along with the new conrods.
Gears and selector drum
Both halves of the crankcase together
Main drive gear, timing gear and oil pump installed
Flywheel, Generator hub and starter drive installed
Cylinders & Pistons fitted
Horizontal cylinder
Vertical cylinder
Both cylinder heads installed
Special home made tool to torque up the cylinder head nuts (thanks to Kris for the15mm spanner 8) )
Stator and water pump covers on
Timing belts fitted
Timing belt covers on - only the clutch left to fit
The clutch, oil seal, housing and cover
Clutch housing oil seal fitted
Clutch installed
All finished - clutch side
Other side
Swing arm and rear shock all rebuilt
Now to put it all back together again...........
