Ducati 888 engine rebuild 1
fatirossi
Well, after 2 years of my 888 being layed up in the garage due to a broken crank, I finally got round to writing about the rebuild. A replacement crank was sourced and provide by a very nice guy on the 888/851 forum for a princely sum of £50 - in great nick too.
Heads were tackled first and rebuilt with 2 new exhaust valves, new valve stem oil seals, camshaft bearings & oil seals, gaskets and st/st bolts.
Checking the run-out on the valves. Both exhaust valves on the front head were bent.
Checking the valve closing rocker clearances.
0.004" inlet
0.006" exhaust.
Measuring the valve shims. Minor differences made good by rubbing down on oil stone.
Heads rebuilt
View to underside - all decoked and valves re-bedded to seats.
View to side.
Next episode rebuilding the gearbox.
