dry clutch replacment
brokenleg
Hi stripped the clutch down today on the ST2 to check the wear on the plates etc. The clutch plates look pretty good, been renewed not long ago. The bike has only covered 20,000 miles. But the clutch basket (steel) is marked up quiet bad with deep slots where the plates have been rattling away. question? do i renew the steel basket or renew the whole lot with an alloy basket with alloy plates or can i put a alloy basket and keep the steel plates.
dont use alloy basket with steel plates, they will wreck it quite fast.
if you have had no problems with the clutch I would simple clean it and repack
If you are replacing the basket go for an alloy one and alloy plates but since the plates you have are ok and the basket hasn't given any problems I'd clean it and put it back together. You could clean up the notches with a file but this will increase the gap, making it rattle worse and further shortening the life of the tabs on the plates.
Thanks guys, today i cleaned the steel plates and basket and put everything back in order, the clutch isnt slipping so i will wait until the fiction plates wear then i can renew the whole lot with alloy.
