Draining 848 fuel tank
Pict
Have you looked out the window? It's winter. I was going to whip off the tank at the weekend and empty a la 748 but looking at the manual it seems to be about a half days job on the 848 compared with one bolt securing tank / one drain screw in tank for the 748. Progress eh? :rolleyes:
So looks like I can disconnect the hose where the 2x fuel lines join at a T-piece, stick on my own bit hose and turn on ignition to pump fuel out. Does that sound reasonable? Or is there a drain screw in the tank that I can't see from the manual? If I am going to empty it I would prefer it to be empty which the pump method won't achieve.
FFS! :mad: Just looked at the manual again - you need to take off the cans, seat AND side panels to get the tank off :thumbsdown:... are you not supposed to maintain these things, just pass them on every year and trade up to the latest marketing w@nk :stir: ???
For Sale; Ducati 848
Wanted; Ducati 900SS
Maybe just pop in a match to get rid of what fuel is left. Off for a decaf.. ;)
Just brim the tank with a wee bit of fuel conditioner and leave it.
I'll sell you a Supersport
I'd do the same Lindsay and if you're going to change the filter you'll have to drain it anyway. I use the fuel pump to drain the ST but you have to take the relay out and bridge terminals 30 and 87 of the fuel pump relay socket so that the pump stays on as long as the ignition is on. It won't totally drain the tank but it will get it down to 1/2 a litre or so. As you've observed there isn't a drain plug on the 848 so you'll just have to empty out what's left once you've removed the tank.
Progress aye!
Don't get the point of draining the tank surely that only matters if the tank is metal. Left my monster full of fuel last winter ran some injector cleaner through it in the spring then kicked it's a@@@e all summer and don't seem to have any probs. Personally I'm more worried about corrosion on the metally bits.
Sorry for ignorance but is the tank on the 848 plastic?
Just that there is a big debate/argument going on in some classic circles just now because the ethanol in the fuel now is destroying plastic/grp tanks if it is sitting for a time.
I understand that it sits at 10% just now but the plan is to increase it to 20% shortly.
There was a case of a guy with a Triton where the fuel tank has been rendered useless because the fuel sat there for some months.
I think the VMCC are on the case but recommendation is to NOT leave fuel in plastic etc tanks when bike is stored.
This link is one of many if you Google Ethanol fuel problems.
May be worth putting this up as a topic on it's own for anyone with plastic tanks on their bikes?
Yes 848 is plastic. I only found out at Bo ness when Chiz told me.
I had a bit of a POR-15 session planned for the SL over winter but this whole ethanol thing has made me think that it might be less hassle taking good care (draining, getting the water out - another side effect of the ethanol) of the tank and being resigned to patching it in the future than dealing with POR-15 gloop at some point when we start being fed fuel that the POR-15 was never designed to work with.
The US already has much more ethanol than us, so it's on its way..
Sorry for the thread switch from 848 to SL
I hadn't realised that the 848 had a plastic tank although I should have known when I think about, all the other models are plastic now. I'd still drain the tank over winter anyway especially now that Stewart's reminded me of the dangers of ethanol in plastic tanks.
One thing though Pict - it's not winter yet! I don't consider it winter until they start throwing salt on the roads.
You must be a richt jessie :p
I have traditionally left the bikes stored over the winter with fuel to the neck to stop condensation and corrosion.
Given the recent publicity I may go the other way now and leave then dry and shove them in a vacuum bag etc instead given the water problems with ethanol.
Wonder if it would affect the plastic petrol cans over a period of time as well?
I had heard tales of it destroying POR15 lined tanks but the publicity seems to be getting racked up now given the UK is planning to increase the percentage in fuel.
Potentially huge safety issues here with this stuff. :(
so explain to me again why its ok to have ethanol laced fuel in a plastic tank so long as your useing it once a week ~:????
Probably isn't OK, but just not very practical to drain after every trip. On the other hand if you are not going to use the bike for 4 or 5 months...
As to accusations of being a Jessie, I do run a bike all year round, just not the 848!
Pumping out the fuel was a bit of a non starter so I just went for the traditional sook through a pipe method ... worked braw, totally empty.
@@@@ all that hassle.:eek: let it rot I say.
If it goes on fire next year I'll just claim off the insurance & buy an EVO.;);)
:D:D Best thing is since I was fannying about with the 848, I just had to use the SUPERLIGHT for a blast yesterday :D:D
Hey, Ive still got those 848 carbon heel plates for you. Home on Thursday the 7th. Will drop them off before I jet of on my happy hols on Sunday.
Will pop doon on the RED (Proper) Colour 900SL.
Keep yer yellow 1/2 cast away from my bike.;);)
Nice one Chiz, give me a shout when you get back!
