diy showa rear shock refresh
thomp1983
Hi, after i finish the engine swap ill be looking to refresh the biposto rear shock. Im happy with the doing of the job but wondered if anyone knew the oil weight used, the amount/air gap and lastly the psi rate for the nitrogen charge?
Thanks
chris
:dunno: No idea. I've seen it somewhere but can't remember but if I come across the info I'll let you know.
I used Motul shock oil. I also used the info in the ducati manual as a guide. It also gives the nitrogen pressure. There is no air gap as there is a rubber bladder for the nitrogen to stop it mixing with the oil and frothing. The Duc book says to renew the bladder but I re-used mine. I've done this on my 748 and 900SS shocks. Both were 'plusher' especially when cold. I would say they function better too, especially the 900SS. I haven't had a chance to thrash them through the mountains yet so I can't really say what they are like once really hot. The Motul oil is a synthetic very high viscosity index oil so it should work more consistently over a wide temperature range. I've been toying with the idea of putting some in the forks. If you have a Showa 'non-rebuildable' shock then stick it in the vice and use a pair of pipe grips to remove the steel cap on the reservoir and twist it off. Voila! A rebuildable shock!
I suppose I better clarify things a little. I pulled the spring of the shock first then bled of the nitrogen from the schrader valve. This allows you to use a hammer and big socket on the end of the reservoir end to tap it down a little so you can get the spring clip out. Then you can take out then end cap followed by the bladder. You then have to take out the damper adjuster on the side of the reservoir.
I then pumped the shock at different attitudes to get as much old oil out. The I sucked in some Motul 2.5 fork oil I had laying about and flush out some more. Now I refitted the bladder and end cap along with the spring clip and pulled the end cap against the clip. I squirted about 3psi of air into the bladder to get it to hold its shape
New shock oil was then poured into the hole for the damper adjuster and the shock worked up and down until no bubbles appeared. I then screwed the damper adjuster lightly home and operated the shock to get any last bubbles out of the reservoir chamber. The I took the adjuster out and did a final top up with shock oil and put the adjuster back in and screwed it finally home.
If I remember right the reservoir pressure is about 9-10 bar. After the reservoir is pressurized it's just to put the spring back on and fit it to the bike.
That's great info, bike tax renewal arrived this week which means this time last year i had the bike out, it's started me itching to ride again
I used Shock Absorber oil not fork oil. The fork oil was only used for flushing. Ducati recommend Showa SS15. Info I have gives it's viscosity at 40c as 20 cStokes. Motul shock oil is 16.1 at 40c, 6.2 at 100c and has a viscosity index of 400 which is higher than any fork oil I have on the list. As you can see, the Motul is less viscous when col so that will probably explain the 'plusher' feel. I'm waiting before tweeking the damper adjusters until I've got the shock absorber good and hot.
