Dished clutch plate.
st3v38
HELLO everyone, any of you guys got a pix of a dished steel clutch plate, ive been told its a dot or dent at the end of a tooth, im in the middle of replacing my old clutch and it seems i dont have any steel dished plates, when i should have two..:eek:
Here's another picture.
Note the small dot and ignore the rusty bits, that plate's been lying around the garage for a while. The biggest giveaway though is that the dished plates are only 1.5mm thick, the others are 2mm.
flipping hack!! its in better nick than some of the ones ive just pulled off :eek: thanks all the same, found one among my lot, had to order a batch of plates, hopefully this will sort my problem..:D
