diavel not starting
vee twin
stopped for toilet break , got back on bike would not start, trailered home thought it might be side stand switch. pulled loom apart and looped it with a wire still not starting. checked voltage in battery through optimate wires 12volts. is this enough juice? had it on optimate for 24 hrs still 12volts, any thoughts anyone? 7yrs old original battery. thanks Davy
Davy, is the fuel pump priming at switch on? Battery should be at least 12.5V anything less I'd be dubious. And straight off the Optimate should be at least 12.7V. Can you measure what the battery voltage is when it is cranking?
hi derek, hope you and family are well, came home today after putting charger on for 24 hrs , stood at 12.2 volts also on optimate noticed that red light glowing. ordered new battery think cell has gone, will let you know how things pan out. many thanks. ps wish nicola was a biker!
hello again, just to let you know we found the fault of non starting diavel, after fitting new battery and checking fuel pump and saw it was getting a spark we tested wiring to pump and all was good. took pump off and took it apart lo and behold 2 wires were rusted so bad they were not making contact. soldered new spades on and bingo! hope this is useful for someone, thanks for input derek.
Snap
I've spent who knows how long trying to track the same thing on my 999. Turned out it was exactly the same problem. Look forward to no more stalling and intermittent starting..
