Diablo vers Diablo corse
Bronco Jr
Hi all,
I'm just about to put my first set of tyres on my 996 (2001 MY) I've got diablos on right now, wondering if I should go Diablo, or diablo corsa.
Its road use only, fairly brisk, but no legend :-) not sure what extra i'll get with the corsas of how long they are likely to last.
I know tyres are as subjective as it gets - but hey, let me know what you think anyway
Thanks in advance
Trevster
id personally say the Diablo's, more than enough for brisk road riding and good milage too, (1.5K on mine so far and little sign of wear)
Welcome to the site Trev, maybe see you around :thumbs:
I've used both on road and track but don't go anywhere near their limits. i.e I can't tell the difference:D
The Diablo Corsa has narrower groves and softer compound compared to the Standard diablo.
I've read that the standard diablo is better in the wet, wider groves for water clearance and the compund is better for the cold/wet.
The Desmo Due series runs on standard dablos come rain or shine as the control tyre.
Ray.
Normal Diablos are superb for normal riding, it's only trackday addicts and poseurs that go for the corsas:D 5k miles on a rear too!
Grooved tyres don't make any difference in the wet which you may find staggering, it's all about heat in the tyre/carcass and the quickest way to generate heat is to have grooves so the rubber moves more.
As an example look at last years BSB opener at Brands Hatch you may recall it was throwing it down, Kyonari, Haslam and Lavilla were all on the podium Kyo running full wets, Haslam running inters and Lavilla running slicks!!!!
I remember watching Gregorio overtaking the front runner decked out in the wet on slicks.... it's all about heat
More than happy with the Std Diablos on the DD racebike, some riders last year did a full season with one set of tyres, mine are showing alot of wear though after one trackday and one raceday - just need a lefthanded circuit for the next round to even them out a bit !
Grooved tyres don't make any difference in the wet ...
Are you sure, as Pirelli said this on their web site "Higher traction and corner grip also in wet, given by an innovative and optimized tread pattern" all the money they invested in rain groove technology and anti aqua planing tread must have been for nowt then. :comp2:
I've used both and perfectly happy with standard Diablos for the road and even occasional track use.
Can get 3500/4000 miles out of a standard Diablo but only 2500 miles out of the corsa.
Very good tyres, both of 'em.
My riding is predomiently road with the occasional track day.
Tread plays a part but more in heating the tyre than getting rid of water, the BSB race mentioned surely proves this (apart from proving Lavilla is a god also), I even recall Rutter and possibly shakey retiring saying it was too dangerous out there and they were on wets
used both & both are fantastic tyres, corsa's dont last as long, thats about as much as i could conclude.
/ian
Thanks everyone, straight Diablos it is then...
just in time for the bank holiday weekend too
have fun all
cheers
Trevster
Sorry that's not strictly true in wet conditions the tread of the tyre is there to clear water from the road so that the tyre can get contact with the road surface. On a wet road the slick tyre will build a wedge of water between the road surface and the tyre causing aqua planing. :)
