Dead Bike Grrrrrr
dancingdog
hello everyone - me again
just spent a pleasant 3 hrs waiting for recovery (god bless me dad)
Problem - absloutly no electrics, bike just died as if I'd turned off the key.
Checked the usual suspects - fuses - loose wire but couldnt find a thing.
the 1 thing I spotted was the battery was boiled dry & hot to touch
any ideas
rectifier maybe :mad: :mad:
one saving grace of the day was badger - set off to find a signal for the mobile & came back with Stella - :D :D
Aye,deffinately the rectifier. Try doin it in a tunnel in the fast lane with everythin fleein at u :eek: :comp2: :beer:
Tip from an irish lad Davie and me met in Rimini, keep the batt topped up, fit an inline filter on the fuel line in the petrol tank before the pump, seems to help so he said.
Cheers Tam
It was Jan telling me about your episode that made me think.
Time to order a retificatorizer then.
I hear Ducati Glasgow have them on special at the min - 2 for a tenner :D
did you have to replace the battery - mine was pretty cooked
Naw, my batt was fine. When the mech removed the rectifier one of the wires was corroded to s..t and had eventually snapped. Looked like acid had corroded right through it but thinkin back it was preety green and solid round the wire so it could have been water contamination over the years :dunno:
Make sure you get the bracket with the new rectifier, mines hingin on by one bolt at the mo :eek:
Just as an alternative, I had a similar situation last winter with my wee Yamahaha when the battery moved slightly and the positive terminal came into contact with the frame. Same symptoms and battery hot. Might be worth checking as there is no cost involved. (Well apart from some insulating tape.)
any ideas
As you say, good old Badger Bait.
I'm only surprised he couldn't find room for yer bike under his seat
