Dash Warning Lights
rockjock620
OK, I want to know if it is possible to replace the dashboard mounted butt fugly warning lights on the Monster with LED's. You know, the neutral, turn signal, ignition, low fuel lamps etc. I think the dash is a fairly mundane piece of design (?) and way too large anyway. What I really need to know is the wiring/connectors needed at the dash. Is it as simple as wiring in the correct resisitor, coloured LED's and making good connections? Any advice would be gratefully received. Mounting them and constructing a new dash/surround/display is no problem, I can do all that. I need a bit of a project for the start of winter.
Oh and while I'm at it, any suggestions for a tasty little rev counter? Where is the drive for it, is it electrical or mechanical?
If it's just a case of converting the bulbs to LED you can buy LED Wedge bulbs off the shelf to do the job. Steve748 was doing this the other week and should have the info. The only one that will give you trouble is the indicator one which has to be bi-directional (i.e. the +ve and -ve swap over depending on what way you are turning). I offered Steve a couple of solutions for this.
Revcounter, don't know but there are a few electrical options on the market all of which will be far easier to fit than a mechanical one.
Thanks Derek, that's sort of what I hoped. Do the wedge LED's come complete (with the correct resistance) ready to just wire in? So where are the connections/take offs found for an electrical rev counter? In the loom, or at the engine?
The wedge LED's just plug straight in, see these
For a revcounter you will need to locate an earth point, a switched +12V supply (+ve side of an ignition coil) and a pulse feed from the ignition circuit (switched side of same ignition coil). That shouldn't be too hard.
DavieG's dash suggestions are nice, but expensive.
Thanks Dave, the Veypor looks interesting. Bit more than I wanted to spend right now, but could be useful for the future :)
rockjock620 said:
does anyone know if the clutch runs at engine speed?
No. Depending on how old the bike is it runs at 0.5 engine speed or 0.534 engine speed. The change was about 1997/8 depending on the model. The primary drive was changed from 2:1 to 1.84:1 using a hunting tooth to spread the wear.
And what's that got to do with dash lights or revcounters? Are you trying to take revcounter drive off the clutch? :confused:
