NeilD
wheels are back from polisher/painter so i need to fit the whel bearings... unfortunately it wasnt me that took them out
so, the rear wheel spacer has unequal lengths on the stepped down part - looking at pics i took, it appears that this goes on the 'caliper' side of the wheel? Now i've only changed bearings before on wheels where the spacer is just floating between the inner bearing races, however on this the spacer appears to fit inside the bearing.. ?
whats best way of fitting? should I fit spacer to one bearing on the bench then fit to the wheel followed by the other side bearing, or bearing in wheel and then fit the spacer? I think the latter may be a bit fraught trying to get the spacer in square?
anyway, heres a gratuitous shiny wheel pic !
2013-03-12 009 by GUZZINEIL, on Flickr
